Activity Forums Adobe After Effects sawtooth effect on solid cubes
  • sawtooth effect on solid cubes
    Posted by Peter Van der zee on October 30, 2007 at 10:53 am
    anyone has seen or heard about the sawtooth effect that appears when constructing cubes from six solid-layers (or whatever footage) activating cast- and recieve shadows and colapsed transformations, with a light on the cube(s) the borders appear sawtoothed.
    anyone knows how to avoid this?
    vanderzee.tv
    Tom Scoville replied 18 years, 10 months ago 2 Members · 1 Reply
  • Tom Scoville
    October 30, 2007 at 9:00 pm
    I’ve seen this too. I made a stack of Post-it notes for a spot and had that same problem. It showed up on different sides as the camera moved in and then out again. I was under a tight deadline, so I didn’t have time to investigate the cause.
    Tom
