Activity › Forums › Adobe After Effects › Saw teeth edges when using extrusion depth and 3d in AE
Posted by Christofer Kellgren on September 21, 2021 at 8:09 pmHi, i will have this “lowres -saw teeth- look” on 3d things i am animating with extrusion depth?
Anybody knows the problem?
Thx! / Chris
Christofer Kellgren replied 4 years, 11 months ago 4 Members · 10 Replies -
Eric Santiago
September 21, 2021 at 10:36 pmAre you viewing it at 1:1 (100%)?
Can you render a high res JPEG and post.
Maybe your viewer is set to a lower res.
Christofer Kellgren
September 22, 2021 at 8:31 am -
Graham Quince
September 22, 2021 at 9:20 amHave you got a flat version of your image, without any 3D?
If so, make your layer 3D, then set the comp to use Cinema4D render. Then expand the properties and you’ll see Geometry options. In there is an Extrusion property which you can animate.
Christofer Kellgren
September 22, 2021 at 10:19 amYes, this is what i have done. But the problem is the resolution/saw-theeth edges i will have in the final render.
Can it perhaps, be something with the camera position/setting? -
Eric Santiago
September 22, 2021 at 12:34 pmWas this from an Adobe Illustrator vector file?
That’s the oddest anti-aliasing I’ve ever seen from a render.
Christofer Kellgren
September 27, 2021 at 9:52 am -
Walter Soyka
September 28, 2021 at 8:05 pmCheck the CINEMA 4D Renderer’s options. This is accessible either by clicking on the CINEMA 4D renderer selector in the lower right corner of the viewer panel, and then choosing “Renderer options…”, or by opening your comp settings, navigating to the 3D Renderer panel, and clicking the Options button.
Inside the C4D renderer options screen, there’s a quality slider. It looks like yours might be turned all the way down. I think the default setting is 25, but you can increase it for better fidelity renders at the cost of longer render times.
Christofer Kellgren
September 29, 2021 at 9:19 am
