Activity › Forums › Adobe Premiere Pro › Saving Transitions in CS6
Posted by Richard Hutt on August 21, 2012 at 4:18 pmI am using CS6 and like a lot of editors I find that a 30 frame transition is not always desirable. I tend to use transitions/dissolves that are 10 and 12 frames long. I know how to do this, but I would like to save them so i dont have to continuously go into effects and change them. When i have a project that has 50 or so dissolves, this tends to get time consuming. CS5 let me save them to a Custom Bin in my effects panel, but i cannot figure out how to do it in CS6. thanks for you help.
RichardBen Waflik replied 11 years, 8 months ago 8 Members · 10 Replies -
Michael Murphy
August 22, 2012 at 1:53 amI haven’t tried to save transitions, but I did save an Effect (Unsharp Mask with special settings) from the Effects Panel in the Source monitor.
Via a right click? I forget.
You can also set the Default for Transitions in the Project Settings from the main menu. You can set both the default type & number of frames.
When you add a clip to the timeline from the Source monitor, you can add it automatically with the Default Transition. Probably the easiest route for you.
Good luck!
Best,
Michael -
Richard Hutt
August 22, 2012 at 12:11 pmMichael thanks for your reply I do appreciate it. Saving the effects are easy. Its been so long since I had tried to save a transition in 5.5 that I guess I forgot that i have to reset the Default. I guess thats what i will do.
Maybe 6.5 can make it possible to save transitions??? That would be nice.
Have a great day.
Richard -
John Webber
March 5, 2013 at 3:24 pmHello everybody,
I’m extremely disappointed, that premiere pro doesn’t allow to save transitions as presets. Can’t believe that in a software of this price range calling itself professional this is not possible. It’s vital if you’re working on projects with a lot of still photos involved or if you’re creating end credits or want to edit audio efficiently.
Just changing the standard preset transition all the time is just not efficient enough.
Please comment, please tell me this is not true!
Best regards, John
John Webber
March 5, 2013 at 3:30 pmHi Richard,
is there a solution to this meanwhile?
Can’t believe it’s not possible! Huge disappointment as critical for my work!
Cheers, J.
Richard Hutt
March 6, 2013 at 5:38 pmUnfortunatley I havent found it out. If you read up in the thread, there is a partial solution using the Set default transition.
Hope this can be fixed for next version.
Kirkovision
March 7, 2013 at 4:24 pmWhere are you Adobe Premier CS6 Team?
This should be a simple fix.
Customizing and saving any style of transitions into a Custom Bin is a basic need.Anybody have a hack for this issue?
Craig Moore
March 25, 2013 at 5:28 pmAgreed, I used to modify and copy transitions a great deal in FCP. It seemed a natural fit for PP, ugh.
Spider Video
https://spidervideo.tv
XDCAM Ex1-R
MacPro FCP3 -
Robert Martindale
September 23, 2013 at 10:19 pmSeriously….I’ve been able to do this in AVID since day one.
Eric Susch
April 9, 2014 at 3:19 pmThe workaround I use is to save all my modified transitions in a dedicated timeline then copy and paste whatever I need from there. It’s clunky but it works.
____________________________________
eric susch
Check out my blog at EricSusch.com
Circle me on google+ eric susch
Follow me on twitter @EricSusch
