Activity Forums VEGAS Pro saving transition settings
  • saving transition settings
    Posted by Sean Simms on May 20, 2010 at 7:18 am
    i saved a transition of a dissolve with a 20 frame per second parameter but every time i try to use it it reverts back to SV’s default 7 or 8 frame setting….how can i change that?
    Mike Kujbida replied 16 years, 3 months ago 2 Members · 1 Reply
  • Mike Kujbida
    May 20, 2010 at 3:47 pm
    If you’re referring to the transition time when adding images to the timeline, this is selected and specified in two different areas.
    Both are in Options – Preferences – Editing.
    Enable Automatically overlap multiple selected media when added and then specify the length in Cut-to-overlap conversion – Amount (seconds).
