Activity Forums Apple Final Cut Pro saving titles
  • saving titles
    Posted by Thomas Whaley on September 29, 2011 at 2:48 am
    How can I save a simple title? Say I create a simple tile in the storyline and would like to use it later in the storyline. I could copy and paste but that would be a real hassle if it is a long storyline. Or, say I would like to use the title in another project. In FCP 7, I would just save the title to a bin. How can this be done in X?
    Thanks for any input.
    Cheers.
    Tom
    Thomas Whaley
    Patrick Donegan replied 10 years, 9 months ago 6 Members · 6 Replies
  • Eli Hollander
    September 29, 2011 at 4:27 am
    In an event, call it, say, “Titles,” create a blank compound clip called, let’s say, “Titles ‘Bin'”. In your project create titles. Copy them. Double click on the empty compound clip “Titles ‘Bin'” and lay down some GAP and paste the title over the gap clip. Keep adding (copying and pasting) all sorts of titles and title templates you are happy with to the “Titles Bin” compound clip, placing them over a gap clip.
    You can give your titles descriptive names, then in the Timeline Index you can filter out everything but “titles”, and you can find and select the title you need and copy it back into a project.
    You can create different compound clips in the “Titles” event earmarked for different style titles.
    Voila: you now have a titles bin in a “Titles” event that you can bring to any project and has all your favorite titles with your favorite settings.
    Done.
    (There is one puzzling thing, and I think it’s a bug: when copying/pasting a title, the font or weight seems to get slightly messed up, but it’s easy to fix. Effects applied to the titles stay with the titles, however.)
  • Jeff Greenberg
    September 29, 2011 at 10:28 am
    A different way that will work (but isn’t a copy and paste…) is to right click on a title you like as a starting point, adjust it in motion (things like fonts) and save it as a future title that will now appear in the titles area.
    This is about the closest you can get in FCPX to a ‘favorite’
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Thomas Whaley
    September 29, 2011 at 8:10 pm
    Thanks for the info. Saving titles in Motion seems to work fine. I will experiment more. I do miss “round Tripping” though.
    Best.
    Tom
    Thomas Whaley
  • Roland Rick
    January 28, 2012 at 1:10 pm
    Many thanks for this working hint.
    However: It’s a little bit tricky. Right click and “save to favorites” on a finished title would have been much easier and more Apple like. Unfortunately Apple is currently destroying the ease of use of their software. I still can’t believe it, that chapter markers are missing in FCPX. Also Compressor 4 can not add chapter markers if you export to a H.264 MOV. You must export to a H.264 M4V format, that – manually set in compressor – chapter markers are added to your output. That’s really worst… 🙁
  • Andrewwalkerkitchen Freshfitted67
    November 30, 2015 at 11:51 pm
    Hey I was having the same problem and accidentally discovered the easy solution. Make your title, and when you’re done, just right click it and hit “reveal in browser”. Boom, your title will be saved as a clip in your browser, and now you can drag it down into your timeline any time you want over other clips. Simply rename it or make an event called favourites, or favourite titles. I hope this works for everyone.
  • Patrick Donegan
    December 4, 2015 at 7:34 am
    I just attempting to on a title card that is a connected clip,
    and the “Reveal in Browser” is ghosted out.
    I also attempted to do this with a clip in the timeline with no “Reveal in Browser” even showing up.
