Activity Forums Adobe Photoshop Saving the save settings in Photoshop CS2
  • Saving the save settings in Photoshop CS2
    Posted by Jack Hilkewich on October 27, 2006 at 1:14 am
    I have to change a bunch of tgas into pngs. Is there a way to get photoshop to remember what I saved my last file as instead of me having to find the png setting each and every time. After about 200 of these it gets a bit tedious. I am on windows xp.
    I tried an action but I couldnt get it the way i wanted. Is there a way to get it to ask you want you want name the file? Right now i can get it to save with no name but then I have to rename it before I can run the action again or it saves over top of it.
    Here’s my ideal wish. The files I want to save are all text to be used as supers in a tv program, I need to save them all as pngs. If I could get it to save them as pngs with a file name that matches the layer name that would make me weep with joy. Any help would be very appreciated.
    Mike Gondek replied 19 years, 10 months ago 2 Members · 1 Reply
  • Mike Gondek
    November 3, 2006 at 8:16 pm
    Try
    file >> script >> export layers to file >> psd
    Then make an action to save as all your files to the png file format, or use a utility if you have one to convert to .png.
    Set your destination to a new folder so you don’t overwrite your files. Check the box called Override action save as (this is most likely what you were missing and woudl liketaek a page to properly explain this.
    Try to see if you can use the .psd since the script does not have .png availabel. Another recomendation is do not use bullet points \/* or special characters as many conflict and will cause the action to fail. Underscore, parenthesis and dashes are safe to use.
