Saving text clip as template
Hi guys. I’m just trying to figure out how to save as a template the text file I created to introduce one section of video so I can reuse the parameters on all the other intros without having to set each one up individually. Tried using copy and paste – didn’t want to paste: tried Make Multiclip – copied, but when I changed the text in the control window, the text on the clip didn’t reflect this change. Used Duplicate to copy – this time changingthe text was reflected, but when I changed the name of the text clip to reflect this new use, the original text clip name also changed (but not the text). There must be a right way to do this…
Cheers, Andy
