Activity Forums Maxon Cinema 4D Saving specific objects
  • Saving specific objects
    Posted by Jason Stirret on January 3, 2013 at 2:55 am
    If I have a set open and want to save an object within the set/file specifically for later use in other sets what it the best method to accomplish this with textures included?
    Thanks in advance!
    Brian Jones replied 13 years, 8 months ago 2 Members · 1 Reply
  • Brian Jones
    January 3, 2013 at 6:27 am
    in the Object Manager you can save selected objects – File/Save Selected Objects or you can Save an Object Preset which will save it to the library either way saves with materials in 14 Save Selected Objects is also in the main File menu too. And you can save objects as an XRef any of those should be good it just depends on what’s good for you.
