Activity Forums Adobe Premiere Pro Saving size / layout of sequence
  • Saving size / layout of sequence
    Posted by Marc Nibor on October 24, 2014 at 7:30 pm
    is it possible to save the layout of the tracks in a sequence?
    saving the workspace does not include the layout of the tracks.
    I need this because I want to toggle between different settings with single click or hotkey
    example:
    layout 1 – the audio tracks are moved to the bottom so that they are not visible at all, the videotracks are expanded vertically so that thumbnails and tracknames are visible
    layout 2 – audiotrack 1 and 2 are move back in sight and are extremely expanded vertically – so that the waveform is clearly visible in detail.
    switching between those two for example takes 10-15 seconds if I do it manually… and I switch all the time between different layouts, depending on what I do.
    Marc Nibor replied 11 years, 11 months ago 2 Members · 2 Replies
  • Paul Neumann
    October 24, 2014 at 11:03 pm
    Set it how you want, click the wrench, save the track preset. You can then assign that preset to a hotkey or they’ll also be listed there when you click the wrench.
  • Marc Nibor
    October 25, 2014 at 10:20 am
    Great Paul, that’s exactly what I wanted. Thank you.
