Activity Forums Adobe After Effects Saving RAM preview instead of render out?
  • Saving RAM preview instead of render out?
    Posted by Jimmy Brunger on December 6, 2006 at 12:03 pm
    Just a quick one – I wondered, provided I’m rendering progressive and not fielded, if I save my RAM preview file to disk rather than preview it then then add to render queue to re-render it, etc. Do I come out with the same file?
    What I mean is – it *looks* the same I think..is anything not rendered in the RAM preview (apart from fields of course) that would be added if I rendered it out traditionally? Justs seems alot quicker if you’ve already spent 5 minutes waiting for the RAM prev, to not have to wait again to properly render it out..
    Never tried it before today, but like I say, the files seem to look the same and are same size.
    Any thoughts ppl?
    Thanks, Jim.
    Jimmy Brunger replied 19 years, 9 months ago 2 Members · 4 Replies
  • Mylenium
    December 6, 2006 at 2:46 pm
    Technically there is no difference if you render at full res. The only thing to be aware of that would make a difference is things like OpenGL and in some cases guide layers.
    Mylenium
    [Pour Myl
  • Jimmy Brunger
    December 6, 2006 at 3:23 pm
    Yeah, usually do my final preview at full res/best qual with mo blur on, so should be ok to use as final renders then? Great..time saved!!
    Don’t really use Open GL to preview much at mo, but if I do I’ll be sure to do some texts to check again the RAM prevs.
    Thanks Mylenium.
  • Jimmy Brunger
    December 6, 2006 at 4:23 pm
    Great stuff, thanks Dave. Like I said, I’d never really thought of not using the render queue..I’ve just always used it and assumed it is the way you are *SUPPOSSED* to render out final work. I guess it’s only really beneficial if you are setting a bunch of renders off at once and leaving them to run, or for multi-format renders.
    Have I got that right?
  • Jimmy Brunger
    December 6, 2006 at 5:30 pm
    Ahh..didn’t see that. Thanks. I’ve replied in that thread.
    Jim.
