Activity Forums Adobe After Effects saving presets??
  • saving presets??
    Posted by Jason Barton on August 25, 2011 at 12:59 pm
    i’m trying to create a presets folder that holds only my favorite presets that i use the most
    will save me a ton of time having to go thru all the folders to reach the same 10-12 presets all the time
    how can i create a folder and place my favorite factory presets in them?
    Jason Mettler replied 15 years ago 3 Members · 2 Replies
  • Stefan Hinze
    August 25, 2011 at 4:10 pm
    i did it the other way arround – i added a number in front of the presets (in my case the “17fx” becouse my bussines runs under a 17 and everybody needs to get aware of the number… muahahah –> just kiddin)
    SO: if i type a 17 in the FX-Search window, i get all my presets
    hope that helps
  • Jason Mettler
    August 26, 2011 at 2:03 pm
    You can create a special folder and move the effects into it. Find ‘Computer/Program Files/Adobe/Adobe After Effects CS*/Support Files/Presets’
    Put folder in here. You can run into trouble if you move a part of a plugin and not the whole thing (Optical Flares, etc.) so try them out as you move them.
    Also to get a folder to stay near the top make its name like this:
    __Folder Name__
