To save an animation preset:
Select the properties, property group, and effects that contain the values or keyframes you want to save, and do one of the following:
Choose Animation > Save Animation Preset.
Click the Create New Animation Preset button in the Effects & Presets palette.
Choose Save Animation Preset from the Effects & Presets palette menu.
Drag the selected items from the Timeline window to the Effects & Presets palette.
Choose Save Selection as Animation Preset from the Animation Preset menu in the Effect Controls window.
Enter a name for your animation preset, and click OK.
Save the file to the Presets folder, which is inside the Support Files folder of the application folder. The preset appears in the Effects & Presets palette. (If you created a new folder inside the Presets folder, the new folder also appears in the palette.)
