Activity Forums Maxon Cinema 4D Saving multiple texture tags in Cinema 4D
  • Saving multiple texture tags in Cinema 4D
    Posted by Jacqueline Dessel on August 10, 2010 at 2:38 pm
    Does anyone know of a way to save multiple texture tags together as one preset?
    In other words, if I have one shader on the front cap of my type, one on the sides and one on the bevels, is there any way to just save all those texture tags together to make it a little quicker to drop them onto other elements in my scene or export them?
    Jackie
    Adam Trachtenberg replied 16 years, 1 month ago 2 Members · 1 Reply
  • Adam Trachtenberg
    August 10, 2010 at 3:48 pm
    You could save your object, or drag your texture tags onto a null and save that object. Then, when you want to use the setup, merge the saved object/scene and drag the texture tags onto your new object.
