Activity Forums Apple Final Cut Pro Legacy saving motion properties in text presets
  • saving motion properties in text presets
    Posted by Andy Schroeder on July 23, 2010 at 6:54 pm
    I’m trying to save a text template I made with drop shadow, but anytime I save it as a favorite effect nothing from the motion properties tab is saved. Is there a way to save motion properties along with your effects presets?
    Jerry Hofmann replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 24, 2010 at 1:40 pm
    Just save the text file with all it’s effects and motion tab settings as a clip in your browser. Then edit this clip in as needed, and modify the text or whatever once a new instance of it is in the sequence. Once you place it in the sequence, you can modify this copy and leave the original intact for use again.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
