Activity › Forums › Adobe Encore DVD › Saving in CS5
  • Saving in CS5
    Posted by Adam Hopkins on January 13, 2011 at 8:33 pm
    Hello, when I save a project in Encore CS5 and it starts going through the list of things it is saving, it is saving untranscoded files that aren’t in this particular project. They are part of the series of discs I’m authoring, but I don’t see how they are related to this particular disc. Is it using these files because they might be in the same folder as files in my current project or are they in my project somehow that I can’t see. It’s really confusing to me and I just started using Encore. I understand that transcoding is lengthy but why does saving and opening take so long? I thought they should just be link to the files, its like they are writing something. It takes maybe 10 minutes to save a project the first time or to open a project. Is this normal? AARG. I’m so frustrated.
    Daniel Ludwig replied 15 years, 8 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    January 14, 2011 at 3:24 am
    Hi Adam,
    encore is creating some meta-datas on your assets while you are importing it, so there might be a delay while starting and saving bigger projects.
    I´m working with CS5 mac and the import/save/open-time is quite ok, but as you are working with a BD-project the process could take a while.
    as you´ve described that you´re working on a disk-set you maybe imported a lot files, and all of them will be loaded even if they are used or not.
    so a good idea would be just to leave these files in your disc-project that will be really used. if something else would be needed you can import it again.
    normally assets should be transcoded prior authoring, so it would be interested if you just simply import avi/mov-files (untranscoded), or if you´ve transcode it with adobe media encoder or something else.
    finally all these processes depending on the speed of your computer as well – fast machine – faster process.
    cheers
    danny
