Activity Forums Apple OS X saving g4
  • saving g4
    Posted by Many on May 17, 2005 at 2:23 am
    Hi, I have a couple of questions and I’m hoping someone can help me figure out if I can fix my powerbook g4.
    Something heavy fell on it.
    _After accident, the screen is broken, I oppened it up and from what I can see the thing fell right on top of the HD and everything else seems ok.
    _When I press the power button it makes a sound as it is turning on and if i press a coupe of things on the keyboard the scren lights up and it looks like there is something on the screen but i can’t tell what it is because is broken.
    _I tried to conect an external monitor with DVI but didn’t get anything. I was told that OS X will have to be start up in order to see the external monitor.
    _I tried conecting it to a second powerbook via firewiere and tried power with T as target disk but it didn’t show in the good PB.
    Is there anything that I could try to figure out what’s wrong by myself?
    I thought about geting a good HD and trying it on, but then if is a new empty HD it will not do anything good for me, right?
    I’m thinking and thinking.
    any ideas more than welcome.
    Thanks.
    many
    Many replied 21 years, 2 months ago 1 Member · 1 Reply
  • Many
    May 17, 2005 at 3:04 am
    Can you install OS X into an external HD?
    I’m just thinking. if it will be possible to run the operating sistem on an external Hd to get access to my broken G4.
    many
