Activity Forums Apple OS X Saving files to the desktop
  • Saving files to the desktop
    Posted by Jhbarlow on August 2, 2005 at 11:08 pm
    I am a video editor and I have been told that saving files to your desktop will impede the performance of your computer, especially when running Final Cut Pro. Is that true?
    Does saving files to your desktop impede your computers performance. Will an apple computer run better if large files are stored on the hard drive rather than on the desktop?
    Chuck Reti replied 21 years, 1 month ago 3 Members · 2 Replies
  • Mark Sloan
    August 2, 2005 at 11:53 pm
    The idea is to save your media files to a different HD than your boot HD. If you only have 1 HD then there will be little difference whether you store it on your Desktop or not.
    But if you are storing to your Desktop you might not be organizing your clips very well. Take some time to plan a file / folder strucutre that will help you in the long run.
  • Chuck Reti
    August 3, 2005 at 5:07 am
    [jhbarlow] “Will an apple computer run better if large files are stored on the hard drive rather than on the desktop?”
    The “Desktop” is simply a directory (folder), in your home directory, on your system drive, that fills up your screen and provides a visual workspace. Its icons, as in any folder, represent files on your hard drive, that happen to be living in a “Desktop” folder. It’s not some mysterious storage area hiding under a rock inside your computer. Under Mac OS 9, the desktop actually was not a good place for longterm, large file storage, for various reasons. Under OS X that’s not an issue, except that organizationally, it’s not good file management practice. As mentioned elsewhere, you should be saving captured media to a drive other than your system drive. Organize apps, documents, etc in appropriate folders. Use the Desktop for temporary stashing of zipped downloads, docs, etc, before moving them to more appropriate locations. You can create desktop aliases (shortcuts) to particular items, or learn how to use the Dock for similar purposes.
