Activity › Forums › Apple Final Cut Pro Legacy › Saving FCP 7 as a FCP 6
  • Saving FCP 7 as a FCP 6
    Posted by Heath Alseike on June 13, 2011 at 3:50 pm
    Does any on know hot to or if it is possible to save a FCP 7.3 to an earlier version of FCP? I am working in 7.3 but a client of mine wants to use the project in the older version of FCP that he has. Is this possible?
    Matt Doe replied 15 years, 3 months ago 2 Members · 1 Reply
  • Matt Doe
    June 13, 2011 at 4:53 pm
    You could export an XML file. They would import the XML file and reconnect to the meda on their end. The media would need to be exact on both ends for this to work as seamless as possible.
    Make sure you export a V4 XML, not a V5, FCP 6 does not recognize the lastest version of XML file.
