Activity Forums VEGAS Pro Saving Events
  • Saving Events
    Posted by Cindy Southall on November 13, 2009 at 10:20 pm
    Is there a way to save an event for use in multiple projects? Eg., creating an intro, or a small set of clips to be used in more than one project?
    Thanks for your help.
    Cindy Southall
    Cindy Southall replied 16 years, 6 months ago 2 Members · 2 Replies
  • Terry Esslinger
    November 13, 2009 at 10:34 pm
    In Vegas an event is an entry on the time line. I am assuming you mean saving a short project such as an introduction. If so, after you have edited your intro to your satisfaction do a “save as”. In the “save as” window be sure that ‘save and trim media with project” is checked. You will then have a veg file that you can ‘nest’ in future projects. You treat the veg file just like a normal media event. Any changes made in your new project will not affect the original veg file. If you want to alter the original veg file you need to open that veg file separately, do the altering and resave. The change will show up in the nested veg file.
  • Cindy Southall
    November 17, 2009 at 10:44 am
    Thank-you for that answer. I had spent hours searching on the web. I thought there must be a simple answer.
