Activity Forums Boris FX Particle Illusion Saving Emitters?
  • Elvis Deane
    December 15, 2006 at 6:26 am
    In the Properties of the emitter, you can just Add to Library, which will place it in the current library, and when you shut the program down or save the library, it will be stored there.
    You can also use the Manage function of the library window to reorganize all your emitters into one library.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
