Activity Forums VEGAS Pro Saving Different Frame Size in Text Media Generator
  • Saving Different Frame Size in Text Media Generator
    Posted by Allen Zagel on September 4, 2008 at 10:47 pm
    Hi
    I’ve looked and looked but I can’t seem to save the 1440 x 960 frame size in the Text Media Generator (text box). Standard frame size still shows up as 720 x 480.
    I tried saving a preset but everything BUT the frame size saves. I still have to manually type 1440 x 960 each time and with hundred’s of text boxes anything I can do to save typing I’d appreciate.
    Isn’t there a way to save that new size. I looked in Options / preferences but didn’t see anything there. I’m missing something becauwse I remember somewhere I could set the default time length.
    As DSE once told me and others using 1440 x 960 gives a sharper text and oh boy! Does it ever.
    Allen
    ASX Media Group, Inc.
    http://www.asxvideo.com
    NEW DVD – Europe, Trains-n-Trams
    Allen Zagel replied 18 years ago 2 Members · 2 Replies
  • Mike Kujbida
    September 5, 2008 at 12:32 am
    Allen, I haven’t found a way to do this either 🙁
    My “solution” is to create the first text event and then copy/paste all subsequent ones.
    You will need to change any required text parameters but at least the size remains constant.
  • Allen Zagel
    September 5, 2008 at 1:03 am
    Hi Mike
    That’s what Ive been doing for the most part is copy/paste. Some I can’t/don’t want to re-create though as I have them pre-made and in another veg file I just copy over. That’s because there’s a pair of generated media. 1 text box and 1 graphic pan/crop, like an arrow. Another I use hundreds of is a little number inside a little black box. To have to re-size that black box is a pain
    Oh well, maybe DSE knows. Problem is sometimes I forget to change the frame size. ugh!
    Thanks anyway
    Allen
