Activity Forums Adobe Photoshop saving cs2 animation frames
  • saving cs2 animation frames
    Posted by Andrei Lutic on July 26, 2005 at 4:41 pm
    Is it possible in photoshop cs2 when creating an animation using the animation pallette to save every frame on a separate image file (with one or few operations) without having to select every frame and save it. For example if I’ve created an animation that has 300 frames and I want to save them it’d be a real torment to save each at a time. Thx
    Andrei Lutic replied 21 years ago 2 Members · 2 Replies
  • Richard Harrington
    August 5, 2005 at 2:14 pm
    File>Scripts>Export Layers to Files
    You can also export a movie from ImageReady
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • Andrei Lutic
    August 8, 2005 at 7:02 am
