Activity Forums Apple Final Cut Pro Legacy Saving complex titles
  • Saving complex titles
    Posted by Paul Dzurec on July 27, 2007 at 11:46 am
    I’m using titles to display the names of different people, and it has a transition on either end. I have been creating it once, then copying it, and using it for each person. If I have to copy and paste something else, then I have to go find the title again, and copy it. Is there a way to save the title with the transitions in my favorites on the effects panel?
    When you do something right, no one will know you’ve done anything at all.
    Larry Asbell replied 19 years, 1 month ago 6 Members · 6 Replies
  • Tom Wolsky
    July 27, 2007 at 11:59 am
    Not with the transitions, no. You might save it in its own sequence so it’s a quicker to get to than scrubbing about in your timeline and losing your position.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Tom Matthies
    July 27, 2007 at 1:35 pm
    I believe that you should be able to just drag your title clip right from the timeline and into a bin. All of the attributes on the clip should stay with the clip. Just use it like any other clip after that. I don’t believe that the transitions can be saves this way though. FCP isn’t running right now, so I can’t check to be sure.
    Tom
  • Tom Wolsky
    July 27, 2007 at 2:29 pm
    He wants to copy and paste the transitions with it. You can’t take the transitions when you drag o the browser.
    All the best,
    Tom
  • John Fishback
    July 27, 2007 at 3:12 pm
    Check out this link: https://www.digital-heaven.co.uk/automotion/ I believe it may do what you want.
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
  • Mike Simpson
    July 27, 2007 at 4:00 pm
    alternatively you could nest the title and copy/duplicate it (and rename) for each time you need to put new text in timeline.
    Place them in the timeline and edit the text for each one.. that way it doesn’t cost you anything and if you get a tpyo just edit the text in the nest.
    Hope that’s correct and helpful.
    mike
  • Larry Asbell
    July 28, 2007 at 7:53 pm
    Furthermore the nesting is a good solution when your title is multilayer, such as with a logo, a graphic backplate or additional type layers.
