Activity Forums Adobe Photoshop Saving as a PDF – displays way too big
  • Saving as a PDF – displays way too big
    Posted by Chris Brett on January 29, 2018 at 6:23 pm
    Hi —– have art worked elaborate A4 invoice in Photoshop
    – all ok but I have a problem when exporting as a PDF to email to client
    — it displays way too big in adobe reader and the type looks dreadful —- its as if adobe reader does not interpret the ‘image size’ settings properly from PS ( ? ! )
    —————— anyone know how how to export so that it actually display as an A4 sheet and is nice and sharp please?????
    ————————————————— chris
    Chris Brett replied 8 years, 7 months ago 2 Members · 2 Replies
  • Tom Van damme
    February 1, 2018 at 8:41 am
    Hi Chris,
    is your resolution set high enough? Anything under 150dpi will look blocky (300dpi usually does the trick).
    And what do you mean with “way too big in adobe reader” – is the page size off? You can check the actual page size under File>Properties…
    Or does it just show a part of the page when you open the file.
    I don’t think there is an option in Photoshop to make PDF files display as “fit to window” by default.
    Tom
  • Chris Brett
    February 1, 2018 at 5:59 pm
    Hi Tom and Walter
    ——– many thanks for your speedy replies – much appreciated
    ——————- I can see this is almost certainly the answer …. will sort in a bit
    —————————————— all the best —————————— chris —
