Activity › Forums › Apple Final Cut Pro Legacy › saving a Sequence Pre Set
  • saving a Sequence Pre Set
    Posted by Greg Barringer on January 31, 2010 at 10:33 pm
    I can’t find a way to save the Sequence settings as a Pre Set. What I did was save a Project with the Sequence settings I want with no media imported, it’s just a blank beginning to start with. From there I can use “Save Project As”. Does that make sense or is there an a better way to start with the same Sequence Settings each time?
    Greg Barringer replied 16 years, 8 months ago 2 Members · 2 Replies
  • Michael Gissing
    January 31, 2010 at 11:26 pm
    That works, but the easiest way is to make a custom easy setup which will also let you save other parameters like device control, pre roll, I/O card output settings etc. as well as the sequence settings.
  • Greg Barringer
    January 31, 2010 at 11:54 pm
    Thank you so much, I see how it works now. Before when I tried that I didn’t see that you could get into details and edit the settings.
