Activity Forums VEGAS Pro Saving a Plug in Pre set with MERCALLI
  • Saving a Plug in Pre set with MERCALLI
    Posted by Wayne Grauel on March 14, 2009 at 10:55 pm
    I’m using Mercalli Pro… i have it tweaked for a certain type of shot that i use with my work..
    I saved the preset plug-in – BUT..when when i launch mercalli again to stabilize another piece of footage.. if i click on my “saved preset”.. nothing happens.. for example – no changes happen on the settings.
    i want a static border and not zoomed and – not to mention a bunch of other little settings..
    Is this not possible..?? i sure hope not!…
    Thanks\
    Wayne
    Wayne Grauel replied 17 years, 6 months ago 3 Members · 3 Replies
  • Graham Bernard
    March 15, 2009 at 11:37 am
    Are you saving within the Vegas Preset section? Just under what would be the “chain”? If this is the case then what I need to do is to write an actual name for the Preset – eg: GB_Plane_1a and if I make some further tweaks to it I can can call it GB_Plane_2a. When I do this I can call back each Preset and I can SEE the settings change. However, you do need to save each one with an individual name.
    Grazie
  • Theo Van laar
    March 15, 2009 at 11:14 pm
    I have the same experience: the profiles work fine but the presets are useless. I can save them, but opening a preset doesn’t bring back the settings. Unfortenately I never found a solution for this. In the meantime I have stopped using Mercalli…
    Theo
  • Wayne Grauel
    March 16, 2009 at 1:30 am
    Graham,
    For some reason I went back to re-createe the problem and perhaps take a screen shot… and it worked.
    I right click on the video clip that I want to work on — mercalli is in the video chain ( if not – click on it to add it to the chain…)
    but today it seemed to work.. perhaps I spoke too soon?..
    Basically.. it is in Sony’s preset right about the Mercalli Profile
    I’ll post again if i have problems
    Yes i am saving in the Preset vegas section right above the mercalli plugin,
    Yes.. i set mercalli to desired settings,, then entered a preset name and hit the save icon..
    So.. i see that it did work this time.. -perhaps it was me post again if i have another problem.
    thanks
    wayne
