Activity Forums Adobe Premiere Pro Saved some money, what should I upgrade?
  • Saved some money, what should I upgrade?
    Posted by Andreas Jorgensen on May 12, 2015 at 9:07 pm
    Hello everyone. I’m a student, and I’ve finally saved up some money for an upgrade to my pc, the problem is, that I don’t quite know what I should upgrade.
    I’ve read that everything from a new graphic card, more ram or a faster HDD will increase performance.
    Here are the specifications for my pc at the moment:
    I7 4820K 3,7 GHz
    Nvidia GeForce GTX 770
    Some random ram blocks (Which I know is a pretty bad idea) – 14 GB ram, locked to lowest speed at 667 Mhz
    Samsung EVO 840 SSD for Premiere, After Effects and Windows
    Old samsung 1 TB HD 7200 rpm for the videos (7 years old and is about to break, and I probably should replace it no matter what)
    I’ve been using Premiere for 1,5 years and I’m beginning to step my toes into After Effects, the problem is when I use After Effects, sometimes a pop-up appears and says that there is not enough memory, and Windows closed it.
    So what is more effective? More CUDA cores? Some stable ram? A faster HDD?
    Thanks 🙂
    Andreas Jorgensen replied 11 years, 4 months ago 2 Members · 2 Replies
  • Craig Howard
    May 12, 2015 at 10:49 pm
    Sort your RAM out is my suggestion.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Adobe CC2014 Suite, Resolve
    Windows 7-64 bit:Assus P6T Deluxe Mob, 24 GB BM SDI Decklink, . HD Workflows
  • Andreas Jorgensen
    May 13, 2015 at 8:05 am
    Thanks for the reply. I will get some stable ram as soon as I can. Thanks again.
