Activity › Forums › Apple Motion › Saved motion sequence not importing totally into FCP
  • Saved motion sequence not importing totally into FCP
    Posted by Tracey Dunn on May 15, 2008 at 4:02 am
    Created short sequence in motion, all stills and a few titles, except last group/segment which is a 6 sec .mov. Nothing too complicated, at least that’s what I thought…..
    Last still is a matching freeze frame from the .mov. Both still and .mov from FCP.
    Saved and opened up in FCP; everything there but the end of the sequence which is black.
    If I create a new project timeline in Motion with just the .mov it imports fine and plays no problem.
    Tried adding a still in front, FCP imported the still and 3/4 of the .mov with the last 3 secs black.
    Essentially I’m round tripping the still and the .mov.
    Tried importing media with file, makes no difference.
    Tried removing .mov segment and importing sequence, but now the last 3 secs of the last still when played in the FCP timeline are black.
    I don’t really want to export it from Motion as a quicktime file; any suggestions?
    Noah Kadner replied 18 years, 4 months ago 2 Members · 4 Replies
  • Noah Kadner
    May 15, 2008 at 7:12 am
    Export as a QuickTime file with no compression or animation codec- this is identical in quality to a Motion project with no issues as you’re having.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
    https://www.callboxlive.com
  • Tracey Dunn
    May 15, 2008 at 11:55 am
    Is this an issue other people are having?
  • Tracey Dunn
    May 15, 2008 at 12:54 pm
    Noah,
    I see from other posts that the Motion Templates cause problems on import into FCP.
    However, I thought this was a problem with Leopard, not Tiger which
    I’m using?
    Thanks for you reply,
    Tracey
  • Noah Kadner
    May 15, 2008 at 7:31 pm
    Like I said- there can be any number of issues that hold up a motion project from rendering properly into FCP. But as the end result is identical, just a bit more time to render out of Motion I say go do that so you’re not hung up.
    Noah
