Activity Forums VEGAS Pro Save text pretext
  • Save text pretext
    Posted by Donald Gibson on August 17, 2012 at 4:31 pm
    I have a problem I used to be able to do this “save a text preset to Video media Generator.” Am I doing something wrong? I pull the text down work on it, have it the way I want it. So I decide to save it. I go to the preset window and type in a name, go to the right and hit “save preset” button, then the problem it does not save.
    I can save transitions that I have recreated. What am I doing wrong or what do I need to fixed it? I have thought about a reload but I don’t want to do that.
    Thanks a lot for your help. What would we do without you guys, thanks?
    Don
    Mike Kujbida replied 14 years, 1 month ago 2 Members · 6 Replies
  • Mike Kujbida
    August 17, 2012 at 5:05 pm
    I just tried this in Pro 8 and it showed up instantly.
    In Pro 10 though, I had to exit the text generator, switch to a different choice in the Media Generator tab and then switch back to Text before I could see it 🙁
  • Donald Gibson
    August 17, 2012 at 7:06 pm
    Mike I am sorry I am using Pro 8. I do not get any results from this action. I also tried going to other Media Generator tabs and coming back still no results. Should I consider reloading Pro 8?
    Don
  • Mike Kujbida
    August 17, 2012 at 8:51 pm
    Don, that would probably solve your problem.
    Just understand that you’ll lose any custom render and FX presets you’ve created.
  • Donald Gibson
    August 18, 2012 at 3:06 am
    Mike thank you. That is why I have been putting it off. Guest I will go ahead and do it. Thanks againg for the help.
    Don
  • Mike Kujbida
    August 18, 2012 at 3:13 am
    Don, before you do that, there’s a way to reset the Vegas prefs. I can’t remember the procedure but I’m sure a forum search will turn it up.
    Good luck
  • Mike Kujbida
    August 18, 2012 at 5:02 am
    Found it. Hold control + shift while opening Vegas.
