Activity Forums VEGAS Pro Save Snapshot To File
  • Save Snapshot To File
    Posted by Joao Souza on January 17, 2013 at 8:13 pm
    Is there a way to set snapshots quality?
    When I click on it, there are no settings, only place to save it.
    Maybe something in preferences?
    Thanks.
    We have so much time and so little to do! / Willy Wonka
    Nigel O’neill replied 13 years, 8 months ago 7 Members · 8 Replies
  • 8 Replies
  • Xana Raquel
    January 17, 2013 at 10:08 pm
    You can only save as JPG or PNG.
    PNG is lossless and JPG is at 90%-100% quality (judging by the file size).
    There isn’t any option for the quality of the snapshot.
  • Jorma Nippala
    January 17, 2013 at 10:29 pm
  • Joao Souza
    January 17, 2013 at 10:52 pm
    It’s already.
    Let’s say I take a snapshot, when I import it, it has less quality, looks a little bit ou of focus/ darker and position is not the same, it moved a little.
    I had to play video with windows media player, pause it and hit print screen.
    Open it in photoshop and saved as jpeg.
    Imported in vegas and it worked but why vegas snapshot isn’t?
  • Roger Bansemer
    January 18, 2013 at 12:28 am
    It use to make a difference several versions back as about setting the preview to full, half, etc. but on the last several versions, it makes no difference that the preview is set to. Either way, the file comes out the same size.
  • Joao Souza
    January 18, 2013 at 2:24 am
    Nope, when I import it has a different position, a tiny difference but you can see it moved and it’s darker with less focus.
    I’m using vegas 11.
  • Aleksey Tarasov
    January 18, 2013 at 4:51 am
    For best results, you need to set Preview quality to Best/Full, Deinterlace method to Interpolate, Field Order to Progressive, Rendering Quality to Best. Then save your snapshot. (if you use Vegasaur’s Snapshots tool, you do not need to complete these steps, just click the button)
    Vegas supports only JPEG and PNG.
    You can set JPEG quality in Internal settings (by default 95%)
  • Stephen Mann
    January 20, 2013 at 3:17 am
    Not since Version 10. The screenshot is always at “best”.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Nigel O’neill
    January 23, 2013 at 11:16 am
    [Joao Souza] “Let’s say I take a snapshot, when I import it, it has less quality, looks a little bit ou of focus/ darker and position is not the same, it moved a little.”
    Interlaced scan refers to one of two common methods for “painting” a video image on an electronic display screen (the other being progressive scan) by scanning or displaying each line or row of pixels. This technique uses two fields to create a frame. One field contains all the odd lines in the image, the other contains all the even lines of the image. A PAL-based television set display, for example, scans 50 fields every second (25 odd and 25 even). The two sets of 25 fields work together to create a full frame every 1/25 of a second (or 25 frames per second), but with interlacing create a new half frame every 1/50 of a second (or 50 frames per second).
    To display interlaced video on progressive scan displays, deinterlacing is applied to the video signal.
    When you take a screen shot, you are effectively only getting either one of the two sets of scans.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 11 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
