Activity › Forums › Apple Final Cut Pro Legacy › Save Project to Raid, Network, or Locally?
Posted by Josh Weiss on April 11, 2006 at 11:15 pmI’ve been working on FCP for abou 6 months now on a pro level. I’ve been saving my projects and media to my raid. I had a coworker today suggest its bad practice to save your project to your raid. I understand his point of having latency and saving projects elsewhere, but its just a bit sloppy. These are 30 second spots with mainly rendered material for After Effects. Does anyone have any suggestions? If you save your project file to your network and media to your raid, will performance suffer at all? Any suggestions on how everyone here likes to workl?
Kevin Monahan replied 20 years, 5 months ago 7 Members · 10 Replies -
Kevin Monahan
April 11, 2006 at 11:17 pmIt’s best practice to have your FCP project file on your Mac HD. Backup the project to a folder on the network nightly.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com -
Josh Weiss
April 11, 2006 at 11:21 pmWill you suffer any speed bump by working on a project folder on the network? Also, if you are going to back up the project file on the network nightly, why not work directly off of the raid?
Kevin Monahan
April 11, 2006 at 11:37 pm[Jwedit] “Will you suffer any speed bump by working on a project folder on the network?”
I wouldn’t want to be subject to any network traffic preventing my files from playing back.[Jwedit] “Also, if you are going to back up the project file on the network nightly, why not work directly off of the raid?”
It’s for safekeeping purposes. If your computer gets crushed to dust, at least you’ll have a copy on the network ( I use my iDisk). You can save it anywhere for a backup, just somewhere that is NOT on your computer.You should not keep your project file(s) on your Media Drive (RAID) as:
1) A drive may fail and if you are running RAID 0, you’ll not only lose the media, but the project file as well.
2) Drives should only contain media on them, as they need to be erased and maintained frequently.Kevin Monahan
fcpworld.com -
Mark Raudonis
April 12, 2006 at 12:23 amJWedit,
I ask that all our editors save in three places: locally, globally, and “mobily”. Locally (your internal drive), globally (the network drives: SAN, SATA, whatever), and onto one of the “removeable” thumb drives. If you follow this every day, I guarantee you won’t lose any data.
mark
Tony! Hulette
April 12, 2006 at 12:35 amDo as Kevin and others suggest: Save your projects to your Mac’s internal drive (not your RAID). Save your media to the RAID. And backup to an external drive or to network location every-night.
Tony!
Sean Oneil
April 12, 2006 at 12:47 amMake sure your Autosave Vault is on a different drive than your project. That way if one dies, you can always acess the other.
Gary Hughes
April 12, 2006 at 3:40 amI completely follow this logic, as I have for years with other NLEs, but you said that the project should be saved on the Macintosh HD. Do you mean that drive exactly, or is any internal drive just as acceptable? I’ve seen posts and articles from others, Larry Jordan for one, that made the same claim, and just passed it off as “they really mean any internal drive”. So here it is again, so I ask for clarification.
I follow the save everywhere method, however, the project file that I actually work on is saved on a second internal SATA drive. My autosave vault is on the system drive. I use Folder Synchronizer from softoBe to synch my projects folder to my powerbook. Do I need to change something?
Gary -
Anders Haavie
April 12, 2006 at 2:39 pmI work in a company that produce broadcast stuff all the time.. realityshows etc..
We ALWAYS save directly to our xraids, but use the internal disk for the autosave vault. We have zero problems with that. We work with dv, dvcpro50 and uncompressed SD material. (no hd yet)
Anders
Kevin Monahan
April 13, 2006 at 8:42 pmWell, what happens to the project file if the Xserve goes down?
I would not keep my project file on any media disk even though you can, doesn’t mean you should.
Perhaps you’re in a situation where you need to share the project file over Xsan?I like Mark’s idea:
Local
Global
Mobile -
Kevin Monahan
April 13, 2006 at 8:44 pmIf it’s working for you, then no don’t change anything. As long as you have a “working backup”, it’s all good.
