Activity Forums Boris FX Particle Illusion Save problem with SE version on Mac…
  • Save problem with SE version on Mac…
    Posted by Vinnie on June 30, 2005 at 4:49 pm
    I have only been able to save the project once each time I open it. When I want to save again the save icon and the menu item under file is grayed out. Also command+S doesnt work either. I have not reinstalled or anything yet…
    has anyone had this happen?????
    thanks
    vinnie
    Vinnie replied 21 years, 2 months ago 2 Members · 2 Replies
  • Alan Lorence
    June 30, 2005 at 7:46 pm
    Once you save a project, if you don’t make any changes to it, you can’t save it again. This is typical of most apps on OS X (if not all). If you make a change to the project you should then be able to save it again.
    You can always use “Save as” if you want to save an unmodified project as another name.
    Alan.
    wondertouch
  • Vinnie
    July 1, 2005 at 2:41 pm
    Ya I am familiar with that. Sorry I should have explained a bit more. But I restarted the computer and we are all good. I dont know why it was doin that. But I did a bunch of tweaks and tryed to save the proj and it wouldn’t so I just used save as and overwrote the proj and it was cool.
    Vinnie
