Save frame at high DPI (masks)
Hi all. I have an animation I’ve made entirely with masks (all bezier curves; thus, vectors). I want to save a frame of it at higher than the default 72 DPI, for print. Is this possible? An even better alternative would be some way to export a frame as an Illustrator or other vector art file. I’ve tried exporting the entire animation as Flash, which works great, but from that point I can’t get Flash to export a frame as an Illustrator file… Thanks for any help.
foon
