Activity Forums Adobe After Effects Save Frame As
  • Save Frame As
    Posted by Michael Bernard on June 8, 2013 at 9:31 pm
    Hi all,
    Basically when I go to Save out a frame of my animation, After Effects is only giving me the option to save it at half resolution, unless I resize it in the renderer which makes it pixelated. I’m basically just looking to export a tiff of one frame at the same resolution of my comp. Is it normal that I cannot do this? or is there a setting that got changed by accident? Any hints would be greatly appreciated.
    Mike
    John Cuevas replied 12 years, 11 months ago 2 Members · 2 Replies
  • Michael Bernard
    June 8, 2013 at 9:34 pm
    I figured out a workaround, which is just make the sequence one frame and render out a tiff sequence… but I’m still curious as to why the save frame as function was being weird. hhmm…
  • John Cuevas
    June 8, 2013 at 11:42 pm
    When you go to make your frame are you using “Current” or “Best” settings. Also is your screen size 100% when you render or are you working at 50%?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
