Activity › Forums › Adobe After Effects › ‘Save frame as’ saving only .psd
  • ‘Save frame as’ saving only .psd
    Posted by Andrew Soh on July 6, 2010 at 10:52 am
    I pray that this is not something that I could have found on the forum, of which I have tried to find but failed.
    Using after effects, to save a single frame I usually just go to:
    Composition>Save frame as>File
    I have been able to choose whatever file format I wanted.
    I now move to a new computer and when I do the same thing I am only able to save the frame as a photoshop .psd file. I cannot choose anything else as .psd is the only file format available from the pull down menu at ‘save as type’.
    Please advise as I need to save in other formats. Thank you very much.
    Specs:
    Adobe After Effects CS4
    Windows 7 Professional 64-bit. (currently running compatibility on vista as a test, problem happening on Windows 7 too)
    Core i7 920
    6gb ram
    Quadro FX570
    Andrew
    Andrew Soh replied 16 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Szalapski
    July 6, 2010 at 1:38 pm
    When it adds the comp to the Render Queue, can you change the format there?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Andrew Soh
    July 6, 2010 at 1:42 pm
    Oh my god I just found that out. I feel like a fool.
    Thanks Michael and please do forgive me and I apologize for wasting your time.
    Andrew
  • Andrew Soh
    July 6, 2010 at 2:30 pm
    Thank you Dave. I was a bit lost at what you were talking about but after some googling and fiddling in AE I believe I now get the gist of it. If I am correct I go to:
    Edit>Templates>Output Module
    -make a new setting, save, etc and next time I go ‘save frame as’ I would have my preferred file format already there instead of the usual .psd
    Thanks for the tip again. Sure does help me save a bit of time rather than manually selecting all the settings over and over again.
    Andrew
  • Anders Hattne
    July 6, 2010 at 7:33 pm
    yupp, CTRL-clicking an preset in the output module will make that the default output module.Not quite what you asked, but a short cut that saved me a lot of repetitive clicking the last week!!
    I love these little gems!!
    http://www.ardillamedia.com
  • Andrew Soh
    July 7, 2010 at 2:32 am
    Yea I just fiddled around with the control-click and it works well. Definitely a time saver. Thanks Anders.
  • Anders Hattne
    July 7, 2010 at 8:45 am
    Found a ridiculous amount of tips on the render queue in this blog..
    https://themographblog.com/
  • Andrew Soh
    July 8, 2010 at 7:15 am
    Oo that is certainly helpful. Thanks again Anders.
