Activity Forums Compression Techniques Save disabling Quicktime.
  • Save disabling Quicktime.
    Posted by Ben Rollason on February 14, 2007 at 1:04 pm
    I used to use Cleaner to compress Quicktime movies. It had a feature that embedded a save disable inside the Quicktime itself (rather than using kioskmode=true which is easy to circumnavigate).
    I’m now using Compressor and can’t find any equivalent feature. Is there a way to achieve this in Compressor or exporting from Quicktime itself?
    Thanks if you can help.
    Ben.
    Fink
    https://www.fink-base.com
    Charles Simonson replied 19 years, 7 months ago 2 Members · 1 Reply
