Activity Forums Adobe Premiere Pro Save custom settings
  • Save custom settings
    Posted by Frank Muldoon on February 2, 2009 at 7:44 pm
    I want to save my custom keyboard setup so I can carry to a different computer. In Final Cut Pro this is easy. I can’t seem to find where the file is saved in Premiere.
    I come from Avid to FCP and don’t want to learn a whole new keyboard layout for PP CS4. Does this seem like a good idea or do all you Premier Pros have other advise?
    Martyn Morris replied 16 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Frank Muldoon
    February 4, 2009 at 5:45 pm
    Since nobody seems to have any idea, I will guess that you could save a project that has your custom keyboard layout and then open that project on another computer in Premier Pro CS4. Maybe your settings will come along. What do you think?
  • Eddie Lotter
    February 4, 2009 at 7:29 pm
    Search your hard drives for a file containing the name you used for your custom keyboard layout. You will probably need to tell the search to include hidden files and folders.
    Cheers
    Eddie
  • Frank Muldoon
    February 4, 2009 at 7:55 pm
    Can’t seem to find any file with the name I saved. I can’t search hidden files.
    I see in the Premiere Package that there are the standard keyboard layouts but no custom files.
    What the @#$% did I do?!?!
  • Eddie Lotter
    February 4, 2009 at 11:18 pm
    [Frank Muldoon] “I can’t search hidden files.”
    Why not?
    Cheers
    Eddie
  • Frank Muldoon
    February 4, 2009 at 11:41 pm
    Don’t know how on my Mac.
  • Raj Swahali
    February 5, 2009 at 3:31 am
    Just hit command-f while in the finder. A search window pops up. Hit the + sign to add criteria, select “Other”. 2 dozen or more criteria choices will pop up. Select “File Visibility”. Then you can choose to search both visible and invisible items.
  • Frank Muldoon
    February 5, 2009 at 4:01 am
    After searching all files visible or not there is no file that has the name of my saved keyboard layout. I have a feeling it is not possible to move this setting to another computer.
    Frank
  • Eddie Lotter
    February 5, 2009 at 2:26 pm
    I dont know why it is so difficult on a Mac. On my computer a search provided the following:
    C:/Documents and Settings/Eddie Lotter/Application Data/AdobePremiere Pro/3.0/EddieShortcuts.kys
    Copying that file to a new computer makes my shortcuts available on that computer.
    Cheers
    Eddie
  • Frank Muldoon
    February 5, 2009 at 4:04 pm
    I just cannot find the file on my Mac. Visible or invisible.
    Thanks for all your effort to find the answer.
    Frank
  • Martyn Morris
    March 6, 2010 at 9:54 pm
    MACINTOSH HD – USER – YOUR NAME – LIBRARY – APPLICATION SUPPORT – ADOBE – PREMIERE PRO – 4.0 – YOURFILE.KYS
