Activity Forums Boris FX Save Composition missing in AvidFX (Boris RED)
  • Save Composition missing in AvidFX (Boris RED)
    Posted by John Mitchell on August 20, 2008 at 3:12 am
    When I run the standalone of Avid FX (the engine) V5.8 Save composition copy appears on the Comp menu but save composition is missing!
    I have to save a copy, delete the original in the project window and then rename the copy. V. annoying!
    Peter Mcauley replied 18 years ago 2 Members · 1 Reply
  • Peter Mcauley
    August 25, 2008 at 1:27 pm
    That’s quite odd – I’m not exactly sure why this is the case. Please try this:
    • launch AvidFX
    • create a new comp
    • name the comp in the project window as test 1
    • save the project as test 1
    • exit AvidFX
    • re-launch AvidFX and open the saved comp
    • make a change to any parameter
    • click on the file menu and you should see Save as an option
    Is that working for you?
    Cheers,
    Peter.
