Activity Forums Adobe Photoshop save as “jpeg” option not there in CS??
  • save as “jpeg” option not there in CS??
    Posted by John Taylor on September 23, 2005 at 9:18 pm
    Hello,
    I don’t use this program much. I created a 16 bit grayscale .psd. When tryin to save as jpeg the option is not there. I recall there used to be many file formats available. There are only five in the drop down menu. Any ideas?
    Thanks in advance,
    JT
    Richard Harrington replied 20 years, 12 months ago 3 Members · 3 Replies
  • Kim Mackenzie
    September 23, 2005 at 9:21 pm
    JPEGs can only handle 8-bits per channel. So you’ll need to save your 16-bit image in another format, or change to 8-bit to make it a JPEG.
  • John Taylor
    September 23, 2005 at 9:36 pm
    Thanks so much for your prompt and informed reply!
    John
  • Richard Harrington
    September 23, 2005 at 9:56 pm
    Or use Save for Web Command
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
