Activity Forums Adobe Photoshop Save As Action
  • Save As Action
    Posted by Jeff Herring on August 18, 2016 at 5:28 pm
    I have a Photoshop template that I want to save the final jpg in two difference locations. I’ve added two “Save as…” menu options to actions and have the folders set up for Drives D:\graphics and F:\backup. But when the menu pops up when running the action it ignores the file location and puts them both on the desktop.
    I can see in the action panel that both save actions show the proper file path “in: D:\graphics\”
    Why is it not going saving them there?
    any thoughts or suggestions.
    Jeff
    Kalleheikki Kannisto replied 10 years, 1 month ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    August 21, 2016 at 3:14 pm
    Most likely you have to turn off the “override action save as commands” option when setting up the batch. (The logic of that option is a bit hazy, so it might be that you need to turn it on instead.)
    Senior Graphic Designer
