Activity Forums Adobe Encore DVD Save and Build’s Save locks Encore with external
  • Save and Build’s Save locks Encore with external
    Posted by Sean David on February 3, 2011 at 12:58 pm
    This could be an Encore issue or a CS5 issue or perhaps a hardware issue, but it doesn’t make sense and I would really appreciate insights.
    I have a simple project on an external drive via USB2 on a 7200rpm 1TB disk, single timeline, one menu, one mpeg2 plus ac3 file set.
    When I save the file, it seems fine, but once I build and then either save or build again, then Encore locks at the beginning of the save at zero progress and only recovers if I unplug the external. It is an issue that I cannot recreate on e.g. the system hdd. However, it doesn’t make sense that I cannot manage files on an external this way, it has always worked before.
    I had a similar lock up issue with InDesign CS5 when both Encore and it were open at once, with InDesign saving on a network drive. Any ideas?
    I have checked the file permissions on the external and the Encore files are all writable. Running on the machine in my signature.
    Sean
    Asus G73JH i7-720, 8GB RAM, Radeon HD5870 1GB, Win7 HP 64 bit, Adobe Production Premium CS5, Cinema4D Studio 11, and more…
    Sean David replied 15 years, 7 months ago 2 Members · 2 Replies
  • Larry Applegate
    February 6, 2011 at 2:18 am
    Just a guess, but USB is not as reliable on catching its errors as Firewire and Sata. I would try a different drive.
    Regards,
    Larry Applegate
    https://blustreak.dvdafteredit.com/
  • Sean David
    February 10, 2011 at 9:10 pm
    Thanks for the reply.
    There are a couple of things I am going to try to figure it out. I had the software installed on the D: hard drive and have reinstalled it on the C drive. That should also solve the irritating message about there being a newer version of Adobe Media Encoder that pops up all the time when stuff isn’t installed on C.
    Then, if it still happens, I’ll try another drive, and then another project. I really wish Encore was more solid though. It chokes on stuff too easily. Premiere works on my externals without a hitch over a range of projects small and large.
    Sean
