Activity Forums VEGAS Pro Save a frame as jpeg
  • Save a frame as jpeg
    Posted by Greg Snidow on May 11, 2010 at 1:06 am
    Greetings all. Is it possible to save a frame as a jpeg image? With Roxio there is a button to do this, but I have not found this option if it exists in Vegas.
    Greg
    Theo Van laar replied 16 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Greg Snidow
    May 11, 2010 at 3:33 am
    Ok, I found it, right after I posted the question.
  • Theo Van laar
    May 11, 2010 at 11:02 am
    And you know that you should have the preview not in the lowest resolution when you make a framegrab?
    Theo
  • Terry Esslinger
    May 11, 2010 at 8:42 pm
    In fact you should have it at “best/full”.
  • Theo Van laar
    May 11, 2010 at 8:54 pm
    ” In fact you should have it at “best/full”.
    No, from version 9d, this is not the case anymore. Thats why I explained it in the way I did. The new rules are:
    Copy Snapshot to Clipboard and Save Snapshot to File now deinterlace interlaced images and operate at Best (Full) resolution if the Video Preview is set to (Auto) size and Good quality if set to Draft or Preview.
    So you can leave the preview settings to AUTO
    Theo
  • Terry Esslinger
    May 12, 2010 at 4:46 pm
    Theo,
    I’ll be darned, I missed that. Thank you.
  • Greg Snidow
    May 13, 2010 at 4:11 am
    Yep, I found that to get the best quality it needs to be in best>full. However, I still see some interlacing affects. Is there a way to deinterlace a single frame? Thanks
    Greg
  • Theo Van laar
    May 13, 2010 at 6:55 am
    Which version of Vegas pro are you using?
    If it is not the 9d version, you can set the project properties at progressive before taking the snapshop.
    Alternatively, you can deinterlace the jpg file in photoshop.
    Theo
