Activity Forums AJA Video Systems SATA II RAID/HD question
  • SATA II RAID/HD question
    Posted by Tpix on September 1, 2007 at 1:36 am
    I might have to set up an HD suite again, sold the last one off 2 years ago.
    Can a SATA II Raid do 1080i 59.94 10-bit HD uncompressed at this time? Last time I could only get 8-bit HD playback which was two years ago on a dual 2.7 G5, PCI-X.
    I have a Quad 2.5Ghz G5 pci-e and was planning on using Kona hardware again.
    Thanks in advance for any help
    Walter Biscardi replied 19 years ago 3 Members · 3 Replies
  • Bob Zelin
    September 1, 2007 at 8:49 pm
    you could have done it back then (2 years ago) with 8 – 10 drives. The rules have not changed. Because you have the old MAC G5 dual 2.7, this is PCI-X. ATTO and Cal Digit do not make RAID 5 cards for PCI-X, so you can either get the Dulce 8 bay RAID 5 SATA array with the PCI-X card, or you can get a RAID 0 solution from Cal Digit – the S2VR with the FASTA-4X SATA host card. You can use anyone elses RAID 0 Sata solution, if you have 8 – 10 SATA drives, all striped RAID 0. Any of the new RAID 5 solutions will work, but all but the Dulce are PCI-E, and you have PCI-X.
    You will also now need the AJA Kona 3X card – the Kona 2 is no longer made. And why do you need 10 bit uncompressed HD?
    ProRes422HQ is not good enough for you ?
    Bob Zelin
  • Tpix
    September 5, 2007 at 12:24 pm
    Hi Bob,
    Thanks for your response…
    I have no problem with the new apple Prores HD codec solution, and hopefully it will gain general acceptance quickly, because I love my old io…and the new io looks sweet…
    but my clients want to hear the word uncompressed…and I always color correct in 10-bit.
    I like to build my own systems because I am a cheap b*stard, so…
    Here’s what I was thinking of doing:
    -Two five bay Kano SATA port multiplier chassis, with WD 750 Gig Raid Edition drives, for ten drives in total striped as a single raid0 volume.
    -I have two of the Sonnet 4 channel pci-e sata cards, so the the raid could be across two slots if necessary. I already have these cards so hopefully they are adequate and I won’t have to purchase something else.
    -I would use one of the two available choices for an AJA HD card…haven’t decided yet.
    My current machine that I want to use is actually a…
    G5 Quad 2.5, {PCI E), 8 Gigs RAM, Internal 1.5Tb SATA RAID 0 system disk.
    what do you think? Good enough for 1080i 10 bit?
  • Walter Biscardi
    September 5, 2007 at 12:41 pm
    [tPIX]
    I like to build my own systems because I am a cheap b*stard, so…”
    There’s a thread right above discussing Fibre vs. SATA for uncompressed with a lot of information regarding SATA for HD
    https://forums.creativecow.net/readpost/98/866754
    I would never build my own arrays as there are too many good companies out there doing that for us and I like the idea of calling them for tech support if something goes wrong. We’re now running two SAS/SATA arrays from MaxxDigital which are running well over 450MB/s, more than enough for 10bit HD.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
