Activity › Forums › Apple Final Cut Pro Legacy › SATA drive question
SATA drive question
Posted by Ernie Santella on August 9, 2005 at 3:47 amJust moved over to FCP5 from Media 100 (I know, what took so long)
I’ve read that SATA drives are the fastest. What do you guys recommend in the 300-500gig range? (Brand/store etc)And what about the SATA/PCI card? I see many drives come with the card included? What type of card do I need for my G5/1.8?
Thanks in advance.
Ernie Santella
Santella Film/Video Productions
http://www.santellaproductions.comErnie Santella replied 21 years, 1 month ago 5 Members · 9 Replies -
Shane Ross
August 9, 2005 at 3:59 amThe HD for Indies guy recommends the FirmTek stuff.
Here is his review:
https://www.hdforindies.com/2004/12/review-of-firmtek-seritek-1se2-and
And here is the Firmtek link:
https://store.yahoo.com/firmtek/
David Roth weiss
August 9, 2005 at 4:28 amShane,
Way expensive — their SATA PCI card seems way overpriced. G-Tech gives the card and a double 7-foot cable with each of their G-SATA drives. I’d check them out if I were Ernie.
DRW
Shane Ross
August 9, 2005 at 4:31 amHmmm…that didn’t seem all that expensive to me. And if they are reliable, and come highly recommended by someone in the video business who tested them, then I’d consider them.
As my Mama aways says: Cheap is as cheap does.
Shane Ross
August 9, 2005 at 4:33 amDang it…why can’t I edit my post?!
Didn’t read well enough. G-Tech is a GOOD company. They produce the G-Raid which is an EXCELLENT drive…so they know there stuff.
Look at them. Pardon my previous post.
Dean Sensui
August 9, 2005 at 8:26 amI use a Firmtek SATA system and it’s been working out nicley.
A good deal is the hot-swap system. If you need more capacity, just get the bare drives, fit them with the Firmtek drive tray ($20 per drive) and you’re all set. Swapping out drive pairs is a simple process, too.
Dean Sensui — http://www.HawaiiGoesFishing.com
Ernie Santella
August 9, 2005 at 1:32 pmWhat physical drives should I get? That article listed the Maxtor Maxline III, the Maxtor DiamondMax 10, and the Hitachi 7K250 and 7K400 drives.
You guys use any of the above drives?
Ernie Santella
http://www.santellaproductions.com -
Peter
August 9, 2005 at 2:02 pmCheck out Mac Gurus – https://www.macgurus.com/productpages/sata/satakits.php and do a search in this forum for SATA for lots of info – Good luck!
Ernie Santella
August 9, 2005 at 2:51 pmAfter reading the Macguru’s article about the Maxtor drives having incompatiblity issues, I decided to go with Hitachi drives and the Firmtek card/bays. Thanks for all your help!
Ernie Santella
