Activity Forums AJA Video Systems SATA DRIVE QUESTION…
  • SATA DRIVE QUESTION…
    Posted by Jim Blokland on May 2, 2005 at 3:54 am
    Hello:
    Putting together a minimal Kona 2 set-up, and want to be able to do DVCProHD and 10-bit SD uncompressed for starters. Given that some of the processing of DVCProHD is handled by the Kona 2…would a single internal SATA drive in a G5 be fast enough to do DVCProHD (more than one stream?)…or is this wishful thinking?
    If not, I’m thinking of a SeriTek card/enclosure with 2 400GB 16MB cache drives raided together (which I could build up to 8 later on…) to handle both DVCProHD and 10-bit. Would this work reasonably well?
    My old Dual 500 G4 set-up never really played back even miniDV perfectly, even though I recall reading that a 7200 RPM drive with an 8 MB cache should have been more than ample to play back DV without dropping frames…
    Any advice appreciated.
    Best, JIM.
    Themightyviking replied 21 years, 4 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    May 2, 2005 at 4:15 pm
    The Single SATA would handle a stream of 8 bit uncompressed, but… 10? probably not.
    It will handle DVCPRO100 footage all day long. Probably a couple of streams at least.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bob Zelin
    May 2, 2005 at 11:18 pm
    Jerry is correct.
    Bob Zelin
  • Jim Blokland
    May 3, 2005 at 5:16 am
    Jerry & Bob:
    Thanks for the info. What is your take on the SeriTek solution? Would a 2-drive SATA array manage 10-bit SD? I’d raid the two internal SATA drives together, but I’m not too excited about having to boot off an external firewire drive.
    Best, JIM.
  • Themightyviking
    May 9, 2005 at 9:04 pm
