Activity › Forums › Apple Final Cut Pro Legacy › SATA drive for DVCPRO HD 100
Posted by Alfred Guzzetti on April 1, 2007 at 6:34 pmIs a SATA drive fast enough for DVCPRO HD 100 or is a Raid array necessary?
ALFRED GUZZETTI
Alfred Guzzetti replied 19 years, 5 months ago 4 Members · 4 Replies -
David Roth weiss
April 1, 2007 at 7:59 pmA single SATA will give you modest performance, but striping two or three together will give you great performance.
DRW
Walter Biscardi
April 1, 2007 at 8:03 pm[Alfred Guzzetti] “Is a SATA drive fast enough for DVCPRO HD 100 or is a Raid array necessary?”
A single FW400 drive is actually fast enough. But a two drive Striped Array is what I would recommend as a minimum for editing DVCPro HD.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”Read my blog! https://blogs.creativecow.net/WalterBiscardi
Russell Lasson
April 1, 2007 at 9:50 pmWhat the other guys have said is great advice. I might add that it depends on the resolution and frame rate because DVCPROHD can range from around 6MB/sec to around 16MB/sec.
720/24P is around 6MB/sec and I’ve edited it over Firewire 400 without a problem. (Firewire 400 is usually capable of about 30-40MB/sec.) It’s not ideal, but should work (most of the time.)
If you’re editing 720/60P or 1080i 29.97, that’s closer to 16MB/sec. Firewire 400 will start to choke with it. I’d suggest at least Firewire 800 or faster for that (even Firewire 800 will start to choke depending on how many streams of video you’re trying to play back.)
-Russ
Alfred Guzzetti
April 2, 2007 at 4:43 pmMany thanks to all three of you for these helpful comments!
ALFRED GUZZETTI
