Activity Forums Storage & Archiving SATA Arrays to SAN
  • SATA Arrays to SAN
    Posted by Pat Mcgowan on July 12, 2006 at 1:47 pm
    I own four Ultrastor model 2080 Sata arrays (8 X 400 GB Hitachi SATA in each box).
    We are running 2 Matrox AXIO boxes, soon to add a third.
    We want to go to a shared storage model, is there a way to do this using our Ultrastors?
    Howard Solomon replied 20 years, 1 month ago 2 Members · 1 Reply
  • Howard Solomon
    July 17, 2006 at 9:22 pm
    You will need to establish a SAN. If you are using the UltraStor units in a Fibre Channel configuration, you can add a switch, we would recommend QLogic SB 5600 Series and MetaSAN from Tiger Technology. Using the MetaSAN client software you can manage and share out the storage between your Axio systems pretty easily. If the UltraStors are SCSI attached units you can purchase an Atto Fibre Channel-to-SCSI Bridge 4Gb FC and dual UltraSCSI connections and share out the storage by attaching to the QLogic SAN switch.
    If you have questions or we can be of additional help, plesae get in touch.
    Regards,
    Howard Solomon
    Howard Solomon
    631-479-2401
    hs@integrityds.net
