Activity Forums Storage & Archiving SAS or Thunderbolt
  • SAS or Thunderbolt
    Posted by Neil Sadwelkar on December 22, 2013 at 9:01 am
    I have a dilemma with having to provide about 40-60 TB storage for a TV show edit (Apple ProRes ‘SQ’ mostly) to iMac systems.
    I’m easily getting Areca 4036 MI boxes which have a Areca 1223 card bundled.
    And I have a couple of Sonnet Echo TBolt-PCIe boxes lying around so I can put the 1223 in it and run the Areca as a TBolt-SAS-Areca config.
    But the 4036 MI is a ‘dead-end’ SAS box so to be able to connect 2 of them I’ll need to use two Areca 1223 cards in two daisy chained Sonnets.
    Or shall I just get the 8040 which have SAS pass-through.
    Or better still the 8050 Tbolt boxes?
    Which will be the better performing of these three in this setup.
    Price is not a concern. Just the wait. 4036 immediate vs 8040/8050 3-4 weeks.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
    Ricardo Reyes replied 12 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bob Zelin
    December 22, 2013 at 5:50 pm
    the 8050 is your best choice at the moment. But as you know, things will change in the next few months.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    maxavid@cfl.rr.com
  • Alex Gerulaitis
    December 23, 2013 at 2:37 am
    ARC-1200 series don’t support SAS expansion, so no 8040 with that controller. 1800 series.
    Other than that – it’s a personal choice. TB boxes are as “dead-end” as SAS non-expanders: with RAID6 and hot spare – 62.5% efficiency. If not worried about efficiency or flexibility (of, say, only array expansion and other niceties of decent RAID controllers) – then 8050 it is.
    — Alex Gerulaitis | Systems Engineer | DV411 – Los Angeles, CA
  • Neil Sadwelkar
    December 23, 2013 at 6:53 am
    Thanks Alex. I think I’ll wait for the 8050.
    I didn’t get the dead end part with Thunderbolt. Or the 62.5% drop in efficiency with pass-through. What’s that exactly?
    And how does array expansion work with SAS ? How’s it different in Thunderbolt?
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
  • Alex Gerulaitis
    December 23, 2013 at 7:38 pm
    I was wrong about 8040. It’s the 4036 that ARC-1223 is not supposed to work with – at least not the SAS expander part – but you say it’s bundled? I’ll look into that.
    A RAID controller isn’t required with 8040, just an HBA. 8040 supports SAS expansion (up to 122 drives via add-on boxes like 4036) – so that might be a good option if you need more than 8 drives in a RAID set.
    [Neil Sadwelkar] “I didn’t get the dead end part with Thunderbolt.”
    Can’t expand a RAID set beyond the number of drives in the box – at least not with Pegasus and Areca boxes.
    [Neil Sadwelkar] “Or the 62.5% drop in efficiency with pass-through. What’s that exactly?”
    Create a RAID6 set with a hot spare with eight drives. Two drives used for parity, one for a hot spare. That leaves five drives worth of usable space – or 5/8th space utilization efficiency (SUE) – or 62.5%. Create a similar set with 16 drives and your SUE goes up to 81.25%.
    I.e. a maximum of 8 drives in a RAID set can be limiting in other ways besides capacity and performance.
    Something tells me there will soon be TB2 arrays with built-in SAS expansion.
  • Ricardo Reyes
    December 23, 2013 at 11:41 pm
    Alex, Let me clear up a few things.
    The ARC-4036ML is a non-expander JBOD Enclosure and requires an ARC-1223-8X RAID Controller. Supports only 8 drive max per controller.
    The ARC-4036 is the expander version which requires an ARC-1882X RAID Controler that supports SAS Expansion and allows you to support more than 8 drives by daisy chaining additional ARC-4036 JBOD expander units.
    The ARC-8040 has the RAID controller built in and requires just a SAS host card like the ARC-1320-8X. The ARC-8040 also supports SAS expansion allowing it to work with ARC-4036 and daisy-chain addtional storage to fit your needs.
    Ricardo Reyes
    Areca Technologies – US Channel
    Ricardo@ArecaUS.com
    http://www.Areca.com.tw
    ***** RAID is not a substitute for proper and regular backups *****
  • Alex Gerulaitis
    December 24, 2013 at 12:43 am
    [Ricardo Reyes] “Alex, Let me clear up a few things. “
    Thanks Ricardo! I was hoping you’d chime in… 🙂
    Forgot about the non-expander “ML” version…
    TB2 version of 8050 a coming? Before Xmas, right? 🙂
    Do you think there will be a version of 8050 with SAS expansion sometime in the future?
  • Ricardo Reyes
    December 24, 2013 at 5:53 pm
    That would be a nice xmas present for everyone…sorry to disappoint. The Areca TB2 8bay is said to be available February 2014, around the same time when Apple starts shipping out the new Mac Pro backorders. =) Keeping my fingers crossed.
    Ricardo Reyes
    Ricardo@ArecaUS.com
