Activity Forums VEGAS Pro Sapphire shake render issue
  • Sapphire shake render issue
    Posted by Jimmy Carter on July 10, 2016 at 5:26 am
    I am using Sony Vegas Pro 13 with sapphire plugin. When I use s_shake on a clip in the preview it works just fine but when I render out the video, halfway through the clip it freezes but still shakes. Anyway I can fix this
    Elle Ledford replied 9 years ago 7 Members · 9 Replies
  • 9 Replies
  • Graham Bernard
    July 10, 2016 at 10:21 am
    More info needed:
    Project Settings.
    The Media Info.
    Render Template.
    * Grazie
  • Jimmy Carter
    July 10, 2016 at 10:02 pm
    Project settings 1920 by 1080 60fps
    Clips 60 fps .avi motion jpeg
    Lenovo
    Windows 7
    Gtx 750 Ti
    Intel core i5
    12 GB ram
  • Colin Wuzhere
    July 11, 2016 at 12:15 am
    I’m also having issues with Sapphire.. I center zoom blur with BlurMoCurves but when i render the video it does not center the blur..
  • John Davidson
    January 24, 2017 at 4:53 pm
    I know this is an old post but i also use s_shake and it also freezes ☹
    It’s so annoying and i cant find a fix anywhere ☹
    OS: Windows 10
    intel i7 4770k
    nvidia GTX 1070
    32Gb DDR3 Ram
  • Graham Bernard
    January 25, 2017 at 4:48 am
    Hi John. You certainly have enough muscle in your rig. Have you tried disabling GPU acceleration? What Preview quality are you running? Does your Project Settings exactly match your Event Media? Have you got any other VFX applied?
    Bottom line, I can use Saphire Edge Shake with no issue. Let’s see if we can nail this irksome critter.
    * Grazie
  • John Davidson
    January 25, 2017 at 9:35 am
    I’ve disabled GPU acceleration but it still freezes.. My preview quality is set to Best and my project settings match with event media. I render in MainConcept AVC/AAC. No other VFX’s are applied. I think it could just be because my footage is in 60 frames per second at 1080p.
  • Oisin Fogarty
    June 29, 2017 at 5:47 am
    hi, this is happening to me but its happening with the glow this is so annoying and i want it fixed i need this edit out
  • Richard Dobell
    August 28, 2017 at 9:31 pm
    Hi, you might have already found a solution but just in case anybody else is struggling like I was… this is caused by your project settings not matching your rendering settings. I found that I was rendering my video in 1080p 60 fps but project settings were 1080p 25fps. I changed this and set 60fps to default, restarted the program and problem solved. Hope this helps
  • Elle Ledford
    September 18, 2017 at 1:20 pm
    I was having the same issue a while back. I found that disabling GPU acceleration worked and making sure your render settings matched your project! If that doesn’t help, then it would most likely be a problem with your processor being too low to support SVP.
    – Elle, Sony Vegas User
