Activity Forums Avid Media Composer Sapphire on Symphony
  • Sapphire on Symphony
    Posted by Dubbs on April 29, 2005 at 1:35 pm
    I am using Avid Symphony and have created a title with the title tool. How and what order do I apply a sapphire drop shadow the the text layer? Do I need to use s_layer or make RGBA first? I am confused about the Sapphire workflow because everything I have tried leaves me with the wrong result in this case. Any suggestions??
    GDubbs
    Mike G. replied 21 years, 4 months ago 4 Members · 3 Replies
  • Todd Beabout
    April 29, 2005 at 4:19 pm
    Yeah it is kindof a weird workflow.
    Use makeRGB first, then add whatever effect (i.e. glow, etc.), then you would normally add S_Layer to see back through your alpha. It so happens though that with Drop Shadow it “layers” it for you automatically.
    So in your case you would use S_MakeRGB then S_Drop Shadow. That should work… it’s still the only way I can add a soft drop to a graphic created elsewhere.
    -Todd Beabout
    Vazda Studios
  • Promopunkk
    April 29, 2005 at 4:53 pm
    make sure you alt drop your effects and layer (or drop shadow)
    the punk
  • Mike G.
    May 5, 2005 at 7:29 am
    Drop S-MakeRGBA onto the title, then alt-drop any applicable effect you like, then alt-drop S_LAYER. The GenArts website has a decent tutorial on this:
    https://www.genarts.com/sapphire-avx-support.html#rgba
